When I attempt to run a demo program supplied with the uVision3 tools, Atmel RM9200 simulation fails.
Steps to reproduce problem
(1) Start evaluation copy of uVision3 V3.34. (2) Open the project: \Keil\ARM\RV30\Boards\Atmel\AT91RM9200-EK\RTX_Blinky\Blinky.Uv2 (3) Select the Simulator target (4) Build target (5) Start/Stop Debug Session
Symptom
*** error 65: access violation at 0x00000000 : no 'execute/read' permission
I got the same error for the STR9. Turned off the FMI to make it work - did this in the config wizard of the startup file, unchecked it.
