Is any direct function is available for the complement of the char variable
A function to take the complement of a char. I even tested it with Keil.
char GetComplementOfAChar(char myChar) { return (~myChar); }
int main(void) { char myChar2;
myChar2 = GetComplemenOfAChar('a'); }
'a' = 0x61 return = 0x9e
"I even tested it with Keil."
And also with your tongue firmly in your cheek, surely...? ;-)
Oh, I think we can do better than that:
char GetComplementOfAChar (char c) { char result; int i; result = 0; for (i = 0; i < 8 * sizeof(c); ++i) { if (((c >> i) & 1) == 1) { result |= 0 << i; } else { result |= 1 << i; } } return result; } // GetComplementOfAChar
I got a better one. const char GetComplementOfAChar[256] = { 0xff, 0xfe, 0xfd, 0xfc, ...., 0x02, 0x01, 0x00 };
myChar = GetComplementOfAChar[0x02]; // returns 0xfd
I'm sure you could've slipped a ternary operator in there somewhere, Drew...?
Barry - he wants a function, so make that:
char GetComplementOfAChar( char c_in ) { char c_out; const char ComplementOfAChar[256] = { 0xff, 0xfe, 0xfd, 0xfc, ...., 0x02, 0x01, 0x00 }; c_out = ComplementOfAChar[ c_in ]; return c_out; }
Note This message was edited to reduce width.
the OP mentioned "this is about a bit" so, let us make it about a bit and we'll earn money when being paid per line of code:
U8 ComplementChar(U8 Phred) { if (Phred & 0x01) { Phred &= 0xfe; } else { Phred |= 0x01; } if (Phred & 0x02) { Phred &= 0xfd; } else { Phred |= 0x02; } if (Phred & 0x04) { Phred &= 0xfb; } else { Phred |= 0x04; } if (Phred & 0x08) { Phred &= 0xf7; } else { Phred |= 0x08; } if (Phred & 0x10) { Phred &= 0xef; } else { Phred |= 0x10; } if (Phred & 0x20) { Phred &= 0xdf; } else { Phred |= 0x20; } if (Phred & 0x40) { Phred &= 0xbf; } else { Phred |= 0x40; } if (Phred & 0x80) { Phred &= 0x7f; } else { Phred |= 0x80; } } // end ComplementChar
Are you sure the OP meant complement and not compliment? Complimenting a charcter would change the whole dynamic of the function and might make a lot more sense. For example:
char *GetComplimentOfAChar (char c) { if (c < 0) return ("You look very pretty today."); if (c < 64) return ("My, you're a handsome character."); return ("My, what a big character you are."); }
Jon
