hi,
I try to get the SSC0 on the MCB-XC167NET working.
I initialize with the following instructions:
SSC0_CON_EN = 0;
SSC0_BR = CPU_FREQ / (2 * SSC0_BAUDRATE) - 1;
ALTSEL0P3_P8 = 1; ALTSEL0P3_P9 = 1; ALTSEL0P3_P13 = 1;
DP3_P8 = 0; DP3_P9 = 1; DP3_P13 = 1;
P3_P9 = 1; P3_P13 = 1;
SSC0_CON = 0xC00B;
That should work, but i get no output on P3.9 and no clock on P3.13. Is there anything I might have forgotten?
Greetings, Simon
Are you sure that SSC0 is enabled in the SYSCON3 register (the default is yes).
hi Chris,
thank you for your reply. I just found the mistake, I use P3L as data lines for a LCD and i accidently switched the direction register for the whole port. now everything is fine.
