I want to use the RV c++ compiler in combination with the ST91 library. I renamed all files in this library to *.cpp and rebuild the library. There is one problem left. Some assembler source files use external symbols. My question :
How can I access UndefinedHandler that is decleared in a c++ file ? I tried with __UndefinedHandler with no success....
AREA Undef, CODE, READONLY ARM PRESERVE8 ALIGN IMPORT UndefinedHandler EXPORT UndefHandler UndefHandler STMFD SP!, {R0-R12, LR} ; Save Workspace & LR to Stack MRS R0, SPSR ; Copy SPSR to R0 STMFD SP!, {R0, R1} ; Save SPSR to Stack (8-byte) BL Undefined_Handler ; Branch to Undefined Handler LDMFD SP!, {R0, R1} ; Restore SPSR to R0 MSR SPSR_cxsf, R0 ; Restore SPSR LDMFD SP!, {R0-R12, PC}^ ; Return to program after ; Undefined Instruction END
Thank you.
extern "C" { void Undefined_Handler(void); }
Declare Undefined_Handler as extern C so that the name is not "mangled". Then the assembler file can find it when it tries to link
Works fine
Thank you
