RealView MDK ARM 3.03a problems and workaround
Hi All,
I'm working with an Atmel AT91SAM7S256 (ARM7 Core) and using the new version 3.03a of MDK ARM Keil Environment. I had discover two problems with this version, but I had also find some workaround for them:
1) Problem about os_sys_init_user function: when you use os_sys_init_user the system go to the Abort Expetions.
WORKAROUND: using the os_sys_init function and after usign the os_tsk_prio to change the priority of the task if necessary.
2)Problem about os_dly_wait: when you use the os_dly_wait the round robin process don't work fine !! It seem the same problem that there was in the version previous at 2.10 version.
WORKAROUND: using os_evt_wait_or instead to os_dly_wait.
If someone would like more details about above two issues, he can reply at this message and I give it him with pleasure.
