Hi folks
I'm using UV3 IDE (V3.33) on a HP Omnibook with Pentium III 850MHz.
While the previous version has had any problem inside the editor this one is unusable. Deleting characters in a line has no affect, at first. So pressing the DEL key again ... nothing. And a third time again ... no action.
5 to 30 seconds later screen updates the line, ups. 2 DEL hits to many.
It seems to be unpossible to run UV3 at this old PC. UV2 hasen't this behaviour.
Is this a UV3 typical problem to makes problems at PCs with similar speed?
Or can I work around it by disabling few settings in the editor?
hopeful - Günter
We did not see this behaviour so far, but you may disable under Edit - Configuration - Editor the .NET Style feature. Maybe this helps on your computer.
