All:
I am writing a few test apps to get familiarized with the peripherals on the LPC2378 ARM7. I am using a Keil MCB2300 board to do so.
I've managed to get Timer0 and Timer1 to generate interrupts on 100 msec and 300 msec intervals respectively. I am trying to set up Timer2 to generate and interrupt similarly. Timer0 and Timer1 both work fine. But, I am having no luck with Timer2.
Unfortunately, the peripheral windows in uVision3 don't yet support Timers 2 and 3, so I can't see for sure if things are getting set correctly. But, I am following the same logic that I used for the first two. Here's the IRQ.C code:
#include <LPC23xx.H> /* LPC23xx definitions */ /* Import function for turning LEDs on or off */ extern void LED_On (unsigned int num); extern void LED_Off(unsigned int num); extern int debug_cntr; /* Timer0 IRQ: Executed periodically */ __irq void T0_IRQHandler (void) { static unsigned int clk_cntr; clk_cntr++; if((clk_cntr%2)==0) LED_On(1); else LED_Off(1); T0IR = 1; /* Clear interrupt flag */ VICVectAddr = 0; /* Acknowledge Interrupt */ } __irq void T1_IRQHandler(void){ static unsigned int clk_cntr1; clk_cntr1++; if((clk_cntr1%2)==0) LED_On(2); else LED_Off(2); T1IR=1; VICVectAddr=0; } __irq void T2_IRQHandler(void){ static unsigned int clk_cntr2; clk_cntr2++; debug_cntr++; if((clk_cntr2%2)==0) LED_On(3); else LED_Off(3); T2IR=1; VICVectAddr=0; }
And here is the main code that sets the VIC and timers up (does some serial stuff too).
#include <stdio.h> #include <LPC23xx.H> /* LPC23xx definitions */ #include "LCD.h" /* Graphic LCD function prototypes */ #define CR 10 #define LF 13 void LED_Init(void); void LED_On(unsigned int num); void LED_Off(unsigned int num); /* Import external functions from Serial.c file */ extern int sendchar (int ch); extern int getkey (void); extern __irq void T0_IRQHandler (void); extern __irq void T1_IRQHandler (void); extern __irq void T2_IRQHandler (void); extern void init_serial(void); unsigned int debug_cntr=0; int main (void) { int count=0; unsigned char val=0; int retval=0; LED_Init(); /* LED Initialization */ init_serial(); /* Init UART */ lcd_init(); lcd_clear(); lcd_print (" RM_Timer "); set_cursor (0, 1); lcd_print (" 11/19/2006 "); /* Enable and setup timer interrupt, start timer */ T0MR0 = 1439999; /* 100msec = 1440000-1 at 14.4 MHz */ T0MCR = 3; /* Interrupt and Reset on MR0 */ T0TCR = 1; /* Timer0 Enable */ VICVectAddr4 = (unsigned long)T0_IRQHandler;/* Set Interrupt Vector */ VICVectCntl4 = 4; /* use it for Timer0 Interrupt */ VICIntEnable = (1 << 4); /* Enable Timer0 Interrupt */ T1MR0 = 4319999; /* 300msec = 4320000-1 at 14.4 Mhz */ T1MCR = 3; T1TCR = 1; VICVectAddr5 = (unsigned long)T1_IRQHandler; VICVectCntl5 = 5; VICIntEnable = (1 << 5); T2MR0 = 1439999; T2MCR = 3; T2TCR = 1; VICVectAddr26 = (unsigned long)T2_IRQHandler; VICVectCntl26 = 26; VICIntEnable = (1 << 26); while(1) { printf("Count= %d",count++); val=getkey(); LED_On(7); //give a little flash to let us know its working! printf("\tYou typed: "); retval=sendchar(val); retval=sendchar(CR); //Carriage Return retval=sendchar(LF); //Linefeed LED_Off(7); } } //**************************************************************************** /* Function that initializes LEDs */ void LED_Init(void) { PINSEL10 = 0; /* Disable ETM interface, enable LEDs */ FIO2DIR = 0x000000FF; /* P2.0..7 defined as Outputs */ FIO2MASK = 0x00000000; } /* Function that turns on requested LED */ void LED_On (unsigned int num) { FIO2SET = (1 << num); } /* Function that turns off requested LED */ void LED_Off (unsigned int num) { FIO2CLR = (1 << num); } /* Function that outputs value to LEDs */ void LED_Out(unsigned int value) { FIO2CLR = 0xFF; /* Turn off all LEDs */ FIO2SET = (value & 0xFF); /* Turn on requested LEDs */ }
Anybody see what I'm missing?
Best Regards,
-=Rich=-
