Wireless 8051 problems
HI :-) as promised, im having problems with the wireless connection on the nordic nrf24e1, I am trying to send a packet and then if received, flash an LED. Can anyone see any problems with the below code. first is the transmitter code then i will reply with the receiver code:
#include <reg24e1.h>
struct RFConfig
{ unsigned char n; unsigned char buf[15];
typedef struct RFConfig RFConfig;
#define ADDR_INDEX 8 // Index to address bytes in RFConfig.buf
#define ADDR_COUNT 4 // Number of address bytes
const RFConfig txconf =
{ 15, 0x08, 0x08, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x12, 0x34, 0x56, 0x78, 0x83, 0x6c, 0x04
const RFConfig rxconf =
{ 15, 0x08, 0x08, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x87, 0x65, 0x43, 0x21, 0x83, 0x6c, 0x05
// LED is to be connected to this pin
sbit LED_pin = P1^0;
// Function prototypes
void DELAY_LOOP_Wait(const unsigned int);
void DELAY_100us(volatile unsigned char n);
unsigned char SPI_ReadWrite(unsigned char b);
void TRANSMIT_Packet(unsigned char b);
void TRANSMITTER(void);
void LED_Flash();
void INIT(void);
void main(void)
{ INIT();
while(1) {
TRANSMITTER();
DELAY_LOOP_Wait()
void DELAY_LOOP_Wait(const unsigned int DELAY) { unsigned int x, y;
for (x = 0; x <= DELAY; x++) { for (y = 0; y <= 800; y++); } }
LED_FLASH()
void LED_Flash()
{ LED_pin = 0; DELAY_LOOP_Wait(1000); LED_pin = 1; DELAY_LOOP_Wait(1000);
DELAY_100us()
{ unsigned char i; while(n--) for(i=0;i<35;i++) ;
SPI_ReadWrite()
{ EXIF &= ~0x20; // Clear SPI interrupt SPI_DATA = b; // Move byte to send to SPI data register while((EXIF & 0x20) == 0x00) // Wait until SPI hs finished transmitting ; return SPI_DATA;
TRANSMIT_Packet()
{ unsigned char i; CE = 1; DELAY_100us(0); // Start with the address of the receiver: for(i=0;i<ADDR_COUNT;i++) SPI_ReadWrite(rxconf.buf[ADDR_INDEX+i]); SPI_ReadWrite(b); CE = 0; DELAY_100us(3); // Wait ~300us
TRANSMITTER()
{ unsigned char b; CS = 1; DELAY_100us(0); for(b=0;b<txconf.n;b++) { SPI_ReadWrite(txconf.buf[b]); } CS = 0; for(;;) { //b = ReadADC(); // Read ADC TRANSMIT_Packet(b); // Transmit data }
void INIT(void)
{ PWR_UP = 1; // Turn on Radio DELAY_100us(30); // Wait > 3ms SPICLK = 0; // Max SPI clock (XTAL/8) SPI_CTRL = 0x02; // Connect internal SPI controller to Radio
    Receiver.C
    A Wireless test program for Nordic nrf24e1.
    COPYRIGHT ---------
    This code is copyright (c) 2007 by Leigh Griffiths.
    struct RFConfig
    unsigned char RECEIVE_Packet();
    void RECEIVER(void);
    void LED_Flash();
    void INIT(void);
    void main(void)
    { INIT();
    while(1) { TRANSMITTER(); RECEIVER();
    DELAY_LOOP_Wait()
    LED_FLASH()
    void LED_Flash()
    { do { LED_pin = 0; DELAY_LOOP_Wait(1000); LED_pin = 1; DELAY_LOOP_Wait(1000); } while(1);
    DELAY_100us()
    SPI_ReadWrite()
    RECEIVE_Packet()
    { unsigned char b; CE = 1; while(DR1 == 0) ; b = SPI_ReadWrite(0); CE = 0; return b;
    RECEIVER()
    void RECEIVER(void)
    { unsigned char b, bo, err; CS = 1; DELAY_100us(0); for(b=0;b<rxconf.n;b++) { SPI_ReadWrite(rxconf.buf[b]); } CS = 0; bo = err = 0; for(;;) { b = RECEIVE_Packet(); LED_Flash(); }
    void INIT(void)
    { P1_DIR = 0; PWR_UP = 1; // Turn on Radio DELAY_100us(30); // Wait > 3ms SPICLK = 0; // Max SPI clock (XTAL/8) SPI_CTRL = 0x02; // Connect internal SPI controller to Radio
  • "Can anyone see any problems with the below code."
    Yes: you didn't follow the instructions about posting source code - so it's illegible!
    Please read the instructions, re-post it as instructed, and use the 'Preview' to confirm that it's worked
    http://www.keil.com/forum/tips.asp
