average of an array
In my project i am incrementing my array 1 and want to find the average of it.
But unfortunately my code is correct when i debugged but it gives an erroneous output when print the output.
I will put my code below can anybody say what is the problem in my function?
float Arr[81][11] = 0;
float Ave[81] = 0;
This is my global declaration.
void Monitor_Slot4(void)
     if(Slot_4 == 0)
        Dev_Curr = fNewVREF_4 / Res;
        DevCurr_MinLimit = Dev_Curr - PassBand;
        DevCurr_MaxLimit = Dev_Curr + PassBand;
        //ROUTINE TO CHECK THE DEVICE VOLTAGE
          for(r=61;r<=80;r++)                            {
                fMonDevVol = 0.0;
               r = r + 12;
                fMonDevVol = fReadVoltage(r);
               r = r - 12;
                Arr[r][s] += 1;
           if(s >= 10)
                flt_Average();
                s = 0;
  return;
The 's' is incrmented in another function where the control returns after executing the above function.
In the above routine when i watch the value of Arr[r][s] in debug mode the value is correct. But if i try to print the value it is showing a wrong value.
Is this due to memory problem.
void flt_Average(void)
     unsigned int u_min,u_max;
     unsigned int u,v;
     average = 0.0;
     Ave[0]  = 0.0;
     if(Slot_1 == 0) {u_min = 1;  u_max = 20;}
     if(Slot_2 == 0) {u_min = 21; u_max = 40;}
     if(Slot_3 == 0) {u_min = 41; u_max = 60;}
     if(Slot_4 == 0) {u_min = 61; u_max = 80;}
  //consider slot_4 is 0
     for(u=u_min;u<=u_max;u++)
           for(v=1;v<=10;v++)
               average += Arr[u][v];
          average /= 10;
          Ave[u] = average;
          if((u >= 61) && (u <= 80))
               SBUF= ' ';
               printf("\n aver is %f",Ave[u]);
               TI  = 0;
               Delay(10000);
               SBUF=' ';
               printf("\n u is %u",u);
               TI = 0;
               Delay(10000);
          average = 0.0;
    return;
In the above function if i try to print the Ave[u], the value is not '1' since in the previous function the value is always '1'.
I do not know where is the problem is?
Can anybody suggest me where the problem is ?
