I am starting to get into uC programming with the Keil MCBSTR9. First step was to rewrite their example Blinky using the ST Software Lib. Compiling, linking worked and so did uploading.
But nothing is happening on the board. So I tried to debug. For some reasons the debugger gets stuck in the Startup file... Any hints?
Help appreciated.
Cheers Nik
Does the standard Blinky work OK?
Yes, it does. What I find mostly confusing is that the STR91x.s is directly copied from the original version. So I do not see a reason, why the debugger gets stuck in it.
Also, I cannot see the current statement that is being processed by the debugger.
Would it help you if I included the source code?
So what is the real difference in your setup then?
Keep in mind: this is not a support forum. It primarily allows you to exchange information with other users.
Hm. Obviously, my code is wrong. I have now mixed the two codes: initialisation is done by the original, LEDs on/off by my code. That works.
Still, in debugging mode, I cannot see, which part of the code is being processed. ???
