hi friends, I am doing a small project on programmble timer.The timer is designed to give control output to each channel according to the timing.the timer starts from 0.0minutes and as it increments to the fullest cycle, it energises relays which fall within the timing. The cycle time,process time and ON/OFF time of each channel can be read on a 8 digit display. can you(any one) give me an idea for implementing this project ?
thanks in advance.
