Hello!
I am working on LPC2138. The flash is 512K and the ram is 32K. As the code exeeds limit of ram i.e. 32K the keil compiler gives error "Execution region RW_IRAM1 size(34624 bytes) exeeds limit (32768 bytes)". Can any body give me some solution???????
Thanks in Advance Fayyaz
You exceeded the ram space of 32K. The same thing has happen in my design. I'm now evaluating my ram requirements and off-loading some of the ram data to a SPI ram memory and paging it in as required.
Please take a look to the MAP file. If you cannot solve it send an email to support.intl@keil.com.
