When I compile my code I get it error " VM.C(174): error C264: intrinsic '_MemCpy': declaration/activation error "
Declaration of "MemCpy" is : void MemCpy(byte *dst, byte *src, int len, byte flag);
Call of "MemCpy" is : MemCpy((byte *)(&dstres), (byte *)VMDstPtr, DstSize, 0);
Declaration of variable is : extern void *VMDstPtr; extern dwrd dstres; extern byte DstSize;
What is reason of this error?
Problem is that 'memcpy' is a ANSI C function and C51 has a tricky in-line implementation for that.
Just rename your function to memcpy_x or so and it should work fine.
