I am using LPC2378.While running the In Application Program(IAP) i do have a problem.The IAP is working perfectly.But after Flashing the application using IAP the application program which is flashed is over clocked, The Real time Clock (RTC) is not working. The UART also gets damaged after few IAP flashing. What could be the problem. Any help in this matter is highly awaited.
Regards, Som Appu
In what way is the UART "damaged"?!
Actually UART is now Ok. I was using the IC ST3232 as RS-232 Transceiver. That IC was gone. But the problem with RTC exists.
Regards , Som Appu
take a look here: www.standardics.nxp.com/.../
on this page you can download a sample source code package that should also show RTC.
