I'm experementing with the MCB2300-board. I have to use two capture-modules but the second doesn't take the Interrupt.s
Can I use every timer to load the capture2? -Or must I use the timer2?
What does the data sheet says?
As well as I understand the data sheet, it has to work. But I'm not the best in English.
When more than one timer may be used to directly drive a feature, the data sheet has to show the relevant registers to configure - these registers will then have bits to specify which timer to use.
In short, whenever a feature is used, you have to check which registers to configure, and what possible values there are for all the bits in the registers.
I think you mean the T[0/1/2/3]CCR. In moment Timer1 works with Capture1.1. But I can't take Capture0, because the net will be used from the LCD panel too. So I use the CAP2.1
I think everything with my initializing is wrong!? :
PCONP = 0; // all Power off^ PCONP |= 0x00680FFE; // I2S-MODUL off, Timer2 on // rest as default PINSEL0 = 0x00000C00; PINSEL3 = 0x000000C0; VICVectAddr26 = (unsigned long)druck_lisr; VICVectAddr5 = (unsigned long)temp_hisr; VICIntEnable = (1 << 26); VICIntEnable = (1 << 5); VICVectCntl26 = 0xF; VICVectCntl5 = 0xE; T2TCR=1; T2CCR=0x00000140; T1TCR=1; T1CCR=0x00000028;
Perhaps there can't be used two capture-modules on the MCB2300?
You may simply dis-mount the LCD panel to free-up the I/O pins.
yes, but I need the LCD panel. in short: I have a board with sensors for atmosphere pressure and for temperature. I Have to measure both and to show it on the LCD Panel.
