Last month, I had wrote a BSP for a board based on LPC2292 and this application is using ARTX kernel.
since last week, I'm trying to run a tiny application using a part of this BSP on MBC2300 evaluation board based on LPC2364 chip. ans I have a problem when i'm trying to put an interrupt function. The information that I can read in µvision3 release 3.11 is not good in vic panel (peripherals). I don't acced to VIcVecAdrx and VicVectCtlx register correctly. When I want to write an interrupt function address into VicVecAdrx regiter, I wrote this address into the channel with the number (see Vic panel)
I've seen the following points : there is a specific rtx_config.c file for LPC2300 family chip there are new parameter in LP2300.s file
Somebody could help me please ? Thanks for all in advance
You really need the current release for the LPC2300 family since these devices have a different VIC.
thanks for your help but it's that i had found
Are you now using the current version (MDK 3.11 - uVision V3.53)?
Thanks for all
I had fixed my problem. there are some difference between Vic controller inside LPC2364 and vic in LPC22xx family
