Hi this is Vishal Khurana a new buddy to keil.... I downloaded many evaluation versions from keil .com like C-166 version 6.08 and C-251 version 4.5 and C-51 version 8.08. In above all when i install them only C-51 is working rest all are not working . when i open a project it says missing tools.ini file and microvision 3 has encountered a problem and has to be closed. I asked for original C.D from keil by post evaluation version only.in dat C.D also i am facing same problem only C-51 is working .plz help me out from where i can get evaluation version downloaded which is working for c-166 n C-251
Are you really evaluating all those compilers at once?!
first i used C-51 and after that i see C-251 it has more added features as compared to C-51 in evaluation version so i installed it but it gives dat message with both C-166 and C-251 Missing tools.ini file plz give me the link where i can get evalution version which is uncorrupted plz help!!!!!
But even if you can somewhere find an evaluation that has 10 times the amount of features as the C-51, you still have to settle for a software that supports the indented processor.
Select processor first, and then decide what tools to use.
Really? Can you summarize what the added features are?
Jon
Well, there is a digit "2" between the dash and the digit "5". Any IDE with a higher model number has to be a more full-featured product :)
