hi there, Iam using LPC2368 based MCB2300 eval. board and iam unable to see the output for the blinky program on the hyperterminal. I have refered the applications notes but problem remains. Iam using a null modem cable (connections 2 to 3, 3 to 2 and 5 to 5) to connect between the UART1(i.e.COM1) of the MCB2300 eval. board and the PC's serail port. Kindly give me your suggestions.
I don't have the MCB2300 eval board but on other eval boards from Keil you need to use a straight through cable. They do the Rx/Tx cross over on the PCB and you cannot use a null modem cable. Check the schematic on the eval board to verify if this is the case for the MCB2300. Bradford
