Hi, A C function tries to call a assembly function via the interfacing way of c programs-to-assemnly interface. Founded it's failed and can't use step-into to watch the status of assembly function. The codes is as follows. Please give some comments for the issue. Tks!
The codes in C.
BYTE show1[3] ={0x0ff,0x02,0x03}; BYTE t_dat[3]; #pragma NOREGPARMS int wrxdata( BYTE *pDs, /* R1-R3*/ BYTE *pSr /*Fixed memory*/ ); main(){ wrxdata(&t_dat[0], &show1[0]); }
The assembly function.
NAME LB_LIBRARY ?PR?_WRXDATA?LB_LIBRARY SEGMENT CODE ?PD?_WRXDATA?LB_LIBRARY SEGMENT DATA OVERLAYABLE PUBLIC _WRXDATA, ?_WRXDATA?BYTE RSEG ?PD?_WRXDATA?LB_LIBRARY ; Segment for local variables ?_WRXDATA?BYTE: ; Start of the parameter passing seg pSr: DS 2 ; byte pointer variable: pSr pDs: DS 2 ; Additional local variables from 'function' RSEG ?PR?_WRXDATA?LB_LIBRARY ; Program segment _wrxdata: MOV DPTR,#?_WRXDATA?BYTE+0 MOVX A,@DPTR MOV DPTR,#?_WRXDATA?BYTE+2 MOVX @DPTR,A RET ; Return END
"Founded it's failed and can't use step-into to watch the status of assembly function"
'Step-into' is a good debugging tool implemented to figure out what is happening in the program, thats alllright, as long as you dont need an excuse to step-into.
Tks,
"A C function tries to call an assembly function via the interfacing way of c programs-to-assemnly interface."
ya, ok, Assembly cud call a c routine, but the required directives need be Included ie to say Connected
ok, now you cud take a tBRreak
You need to review the different pointer types (generic and memory specific) and their formats in order to make this work.
http://www.keil.com/support/man/docs/c51/c51_le_ptrs.htm
In particular, "generic" pointers (those without a specific memory space specifier) are three bytes long, not two. They include a tag byte for the address space. (That's why they're passed in R1-R3, using three bytes of register space instead of two.)
You don't show the defintion of BYTE, but I assume it's just "unsigned char" or similar, and not something like "unsigned char xdata".
