A pointer of array (byte *) passing in fixed memory location
A C function tries to call a assembly function via the interfacing way of c programs-to-assemnly interface. Founded it's failed and can't use step-into to watch the status of assembly function.
The codes is as follows. Please give some comments for the issue. Tks!
The codes in C.
BYTE show1[3] ={0x0ff,0x02,0x03};
BYTE t_dat[3];
#pragma NOREGPARMS
int wrxdata(
        BYTE    *pDs, /* R1-R3*/
        BYTE    *pSr /*Fixed memory*/
main(){
wrxdata(&t_dat[0], &show1[0]);
The assembly function.
NAME    LB_LIBRARY
?PR?_WRXDATA?LB_LIBRARY         SEGMENT CODE
?PD?_WRXDATA?LB_LIBRARY         SEGMENT DATA    OVERLAYABLE
PUBLIC _WRXDATA, ?_WRXDATA?BYTE
RSEG ?PD?_WRXDATA?LB_LIBRARY    ; Segment for local variables
?_WRXDATA?BYTE:                 ; Start of the parameter passing seg
pSr:    DS  2   ; byte pointer variable: pSr
pDs:    DS      2
; Additional local variables from 'function'
RSEG    ?PR?_WRXDATA?LB_LIBRARY ; Program segment
_wrxdata:
                MOV             DPTR,#?_WRXDATA?BYTE+0
                MOVX    A,@DPTR
                MOV             DPTR,#?_WRXDATA?BYTE+2
                MOVX    @DPTR,A
                RET                             ; Return
                END
