I am devoloping applications on a device which uses ARM9. While powering up it starts panicking (it will keep powering up and powering down) - On collecting logs from a panicking parser tool, along with other register information it shows -
Stack Pointer (r13): + 0 bytes Link Register (r14): <a function with arguments(pointers to some string locations)> + 10 bytes program counter(r15): < same function> (as above) + 2 bytes
Does this mean Data Abort is failing in this function? How could this be tracked and solved?
