Sir I m studying in M.Sc. Electronics & for my project i want assembly or keil codes for pulse measurement for MCS51.
Thanking You
andy, (why do you hit the poor fellow so, ) could give suggestions like use timer, interrupts ...
The "poor fellow" says (s)he is studying for an MSc.
Presumably, this means that (s)he must already have a Bachelor's degree?
I don't think it's unreasonable to expect that a graduate should be able to do some basic research and at least come up with some idea of how to approach the problem.
In my day, the internet was not available so we just had to go down to the Library and read through the books, journals, etc...
Now you have Google and direct access to manufacturer's entire datasheet and support libraries - how easy does it have to be?
Youth o' today...
But the term paper was a copy from the net :( and now reality suddenly hit
"assembly or keil codes..."
is there a difference between pseudo code, and actual working code, could guide the young graduate thru the what-after-what to be done,
ok give up, in fact had given up,
talk of interworking..., ok, leave that, got any little tasks to be done?
