Hi Aim doing project on 89C51 In my project i want to store the set point values in EEPROM (I2C). How to store the set point values in the EEPROM and how to retrieve the set point from EEPROM using SDL and SDK lines. Can you give related example projects and material?
Regards
chandu
http://www.keil.com/download/list/c51.htm
www.google.com/codesearch
Also, check the Datasheet for your EEPROM, and search the manufacturer's website for examples, application notes, etc.
One micro thinkss up of something to say or rather "Ask " and micro is back to his "anger" at it, :
what is to be done dear, say sommmething,
Np wonder you are lost. The least you could do would be to name the signals correctly (SCL & SDA) - or is it that the chip you want tpo use is not IIC?
Regarding the post containing:
"One micro thinkss ..."
Andy, is somebody forging your name?
"Andy, is somebody forging your name?"
and such a convincing impersonation, eh?!
See: http://www.keil.com/forum/docs/thread8643.asp
hannah rajan he rajil hems rajeil he rajan hems raj raghu rajil Raghu Ravi ala ninan abe anne
They(?) all write so similarly peculiar that I believe them to be a singular it.
... I believe them to be a singular it.
And since it writes like the new and inferior Andy Neil, and it is so name-morphic, it's probably the imposter.
I just thought Andy was getting all poetic on us.
"dishonest, pirates, illegal version, playful, wat not,"
Has sort of an ee cummings quality to it, don't you think?
Something there is that does not love a clock That couples to the ground plane under it And rounds the upper corners on the scope And makes slips even two bits can pass abreast...
"Has sort of an ee cummings quality to it, don't you think?"
You know, you're right! Next up, Andy on Oprah's Book Club ;-)
not to mention abcd abcd ...,
did the research properly,
"not to mention abcd abcd ...,
did the research properly,"
Poor job, you silly monkey. When impersonating Dan Henry, you'll have to start by at least capitalizing and punctuating correctly.
