about ISP mode
Hi all, I am working on LPC2214 using KEIL compiler.
I am able to enter the ISP mode from user mode by manipulating the P0.14 pin and able to program the chip.
But how can I reset the board, without touching it.Actually i needed this information for remote programming of my controller.Is it really possible?
If I can do this using IAP programming ,Then i want to run my own ISPcode in RAM. How can i execute the code in RAM?
Please help me in solving the problem.
Thanking you,
Yours sincerely,
Sunil.
  • P0.14 ?
    Each port has how mny bits ?
    why do you want to try such magical things, reset without touching the board!
    switch off power supply and switch on again,
    i think there is an option,
    break open the lock, dinosaurs WILL be good at it,
    may not be possible , but its plausible,
    "How can i execute the code in RAM?"
    run your own ISP code,
    should work,
  • P0.14 ?
    should work,
