I am facing a problem in using the right shift operator in C with keil. The instruction is:for(i=0;i<=8;i++) { j=sum>>i; } where sum= 32 bit no. the instruction is not executed if the syntax is as shown above. but if i write a numerical value instead of using the variable name 'sum' then the instruction is easily executed. i need to use the variable name only. how do i fix this problem?
Try this
sum >>= 8; // right justify by 8 bit positions
or create a union
i tried doing this but it doesnt work.
this is the actual code i am referring to:
Good. However, you still have not explained what the code is supposed to do, what it is doing, and why you think it does not work properly.
for(count=0;count<=15;count++) /* adding 15 nos. */
If that means that the loop should add 15 numbers, then you've got a bug - this loop will add 16 numbers. Could this be why you are not getting the result you expect ?
for(i=0;i<=8;i++) { j=sum>>i; /*moving msb 8 bits of 16 bit sum on port 1*/ }
This code snippet does not move anything to P1. In fact, what it does is equivalent to
j = sum >> 8;
, but wastes a lot more cpu cycles.
the code is for adding 15 nos and then finding the average. the problem i am facing is: if the synax is as follows:
j=sum>>8;
the instruction is not executed. but if i put a numerical value instead of the variable name sum then the instruction is easily executed. Similarly if the syntax is as follows:
avg=sum / 0x0f;
the above instruction is not executed using the variable name 'sum'. Since i need to use only variable names in the code what can i do about the above mentioned problems.
"Since i need to use only variable names in the code"
Why is that?
Despite many requests, you still have not explained why you need to do this shift in a loop, rather than simply
"the above instruction is not executed"
How have you confirmed that it is actually "not executed"?
Have you examined the generated code?
Have you stepped through it in the simulator?
"the above instruction is not executed using the variable name 'sum'"
Just a thought: have you checked that 'sum' hasn't been defined with some special meaning, etc...
What if you call it 'my_sum' or something?
yes i have confirmed that it is not executed. yes i have examined the generated code. i did single stepping and found that these instructions are not executed.
and i have done away with the for loop and instead just used:
yeah i have checked that too. even if i replace 'sum' by any other varible name say 's' or 'x' or whatever, it is still not executed
"yes i have examined the generated code."
And what did you observe?
"i did single stepping and found that these instructions are not executed."
Again, what did you observe?
This should tell you why they weren't executed!
"i have done away with the for loop and instead just used..."
Again, you still haven't explained why you wanted the for loop in the first place!
"this is the actual code i am referring to:"
The code will only work with the small memory model. What model are you using?
What do you expect to happen when main() returns (aka, running off the end of main)?
If the optimizer is smart enough, it could eliminate the loop entirely, and just replace it with "j = sum >> 8;" as that's the net effect of the loop. Have you checked the .lst and .cod files to see what the code generator generates? Alternatively, you could temporarily declare j and sum "volatile" to force the optimizer to read/write them on every pass. Or disable the optimizer.
ACC=sum; P0=ACC; B=j; P1=B;
More simply, just
P0=sum; P1=j;
In general, it's not safe to directly manipulate the 8051 registers from C code. You don't know exactly what the code generator will be doing with those registers to implement all the other C statements. For any given release of a particular compiler, you can inspect the assembly output and decide that in this particular case you can get away with it -- but things can change on the next compiler upgrade or even if you rearrange your code. The point of using a high-level language is to leave details like register management up to the compiler. It's tricky to mix the two.
The 'for' loop is to right shift the contents of the variable 'sum'. 'sum' holds my 16 bit result. now i want to move this result in two 8 bits registers of the microcontroller. for that moving the lsb 8 bits of the result is simple. but the msb 8 bits have to be brought to the lsb position first to move it into an 8 bit reg. hence i used the for loop. but now as per your advice i have done away with the for loop and simply used:
But still the instruction is not executed. is there any other alternate way of moving the 16 bit result in 'sum' to the registers of the microcontroller?
these are the warnings i am getting after compiling the program: *** WARNING L1: UNRESOLVED EXTERNAL SYMBOL SYMBOL: ?C_STARTUP MODULE: vkd.obj (VKD) *** WARNING L1: UNRESOLVED EXTERNAL SYMBOL SYMBOL: ?C?SLSHR MODULE: vkd.obj (VKD) *** WARNING L1: UNRESOLVED EXTERNAL SYMBOL SYMBOL: ?C?SLDIV MODULE: vkd.obj (VKD) *** WARNING L2: REFERENCE MADE TO UNRESOLVED EXTERNAL SYMBOL: ?C?SLSHR MODULE: vkd.obj (VKD) ADDRESS: 008AH *** WARNING L2: REFERENCE MADE TO UNRESOLVED EXTERNAL SYMBOL: ?C?SLDIV MODULE: vkd.obj (VKD) ADDRESS: 00A0H Program Size: data=46.0 xdata=0 code=170 creating hex file from "T8-11"... "T8-11" - 0 Error(s), 5 Warning(s). and because of these warnings the code is not getting executed
These are Linker warnings.
It'll be because you've used the SRC directive.
The SRC directive causes the compiler to convert 'C' source to assember source; it is then the assembler that converts this to object files.
Therefore, all the Linker sees is a load of assembler-generated objects; Because the Linker sees only assembler-generated objects, it doesn't automatically include the C runtime libraries - which is why you get these errors.
As has already been noted, you don't need inline assembler for any of this.
Therefore, re-write your code fully in 'C', and remove the SRC directive!
http://www.keil.com/support/docs/1980.htm
thank you so much!!!!!!! i did not have to rewrite the whole code in 'c'. the link you sent in your message provided the solution. i just had to add a file called 'C51S.LIB' to the source group and now the compiler is showing 0 errors and 0 warnings and my code is running successfully. thank you for all your help and time.
"i did not have to rewrite the whole code in 'c'"
True, but it would be wise to do so!
Using inline assembler and the SRC directive brings a number of issues - you have seen just one of them.
So, unless you really need it, do not use inline assembler and the SRC directive.
In general, if you need to use assembler it's far better to write a separate assembler module and call it from 'C'.
"Let your 'C' be 'C' and your Assembler be Assembler"
In your case, as already noted, there is no reason at all to use assembler - let alone inline assembler!
