I want to use external interrupts on Pin P1.2 & p1.3 for frequancy measurement When Positive transition occours on pin External interrupt should be occour And in interrupt vector I want to increment one count time base is generated by timer 0 for ).1 seconds.
My probelm is even thouh frquancy of 1 Khz is applied to Pin P1.2 interrupt is not generate.
I want to know regisier detail configurations of resigistrs so that externl interrupt will generate
Ignorance of the hardware is no excuse, it's "bible time"
here are the links to "the bible" Chapter 1 - 80C51 Family Architecture: www.nxp.com/.../80C51_FAM_ARCH_1.pdf
Chapter 2 - 80C51 Family Programmer's Guide and Instruction Set: www.nxp.com/.../80C51_FAM_PROG_GUIDE_1.pdf
Chapter 3 - 80C51 Family Hardware Description: www.nxp.com/.../80C51_FAM_HARDWARE_1.pdf
You don't have to set much to get the interrupts.
Here is some very basic code.
#include <reg517a.h> volatile char events_cc2; volatile char events_cc3; void T2_CC2(void) interrupt 12 { events_cc2++; } void T2_CC3(void) interrupt 13 { events_cc3++; } void main(void) { EAL = 1; /* globally enable interrupts */ T2CON |= 0x11; /* timer with auto-reload */ EX5 = 1; /* CC2/ext5 interrupt is enabled */ EX6 = 1; /* CC3/ext6 interrupt is enabled */ /* Capture on positive transition at pin P1.3/CC3 * Capture on positive transition at pin P1.2/CC2 */ CCEN = 0x50; for(;;) { } }
Thanks for your reply.
My hardware is perfect because if i measure the freqauncy by polling port pin for 0.1 sec using timer 1 it shows (for 1Khz it show 100 count = 0.1 sec time base.) Frequancy present at one i/p at time. so f_counter one variable is used for both. timer 1 is used for 0.1 sec time base code is not added here to make it small to read My code is something like this
P1_2 |=1; //frequancy i/p 1 (Rotor 1/INT 5/cc2) P1_3 |=1; //frequancy i/p 2 (Rotor 2 inpINT 6/cc3) T2CON |=0x11; //|=b00010001; f oscilator/12 CTCON |=b00000000//msb bits of T2CON & CTCON EX5=1; //enable ext int 5, P1_2 EX6=1; //enable ext int 6, P1_3 EN2 |= b00111100; //CCU int enable bits EAL=1; //enable global int CCEN =0x50; //cap on rising edge p1.3 & p1.2) //CMSEL =0xff;
for ( ; ; ) { _SRVWDT(); //watchdog
//*****scratch pad trial code****** SET_CURSOR (1,0); DISP_STRING ("= ",0); DISP_DEZ(f_counter,5,0); //Display freq dec. form }
//**************************************************** void EXT5_int (void) interrupt 12 //using 2 { f_counter=f_counter+1; } //**************************************************** void EXT6_int (void) interrupt 13 //using 2 { f_counter=f_counter+1; }
