printing float values gets no result
I'm trying to use printf with the %f format specifier to display some floating point values but nothing gets printed. I can print integers values just fine using the %d format. Has anyone else had this problem? I'm using the latest Keil C compiler and libraries on a Triscend 8051.
Thanks,
Miles
My test code looks something like this:
void test()
float x = 1.56;
printf( "test = %f",(float)x);
It will always print "test = "
  • I figured it out, although I still don't quite understand what happened. I had an older routine that I wrote named Printf, which did not have a %f parser in it. Somehow the linker was calling that routine, even though I was spelling "printf" in the code with a lower case 'p'. When I removed all the calls to "Printf", then I guess it had no choice except to call the library "printf" function.
