Need help!!!
Hi I am new in C language... I am doing a project that requires me to program 8051 to LCD in C language...So I am trying to display "HELLO WORLD" to the LCD in C language...I am using a C8051226 and a PIC0802-A 8X2 LCD...
I have gone online to search for sources on programming LCD...I have found a few sources in C and asm...Like www.8052.com/tutlcd.phtml and http://www.keil.com/appnotes/docs/apnt_161.asp...
I have tried to program myself based on http://www.keil.com/appnotes/docs/apnt_161.asp but the LCD does not display anything instead it displays "black pixels"...
I am also having problem configuring the ports...
I will be grateful if any of you guys can tell me how do i write these LCD data bus to the 8051 ports in C language??
DB0 EQU P3.0
DB1 EQU P3.1
DB2 EQU P3.2
DB3 EQU P3.3
DB4 EQU P3.4
DB5 EQU P3.5
DB6 EQU P3.6
DB7 EQU P3.7
DATA EQU P3
  • but the LCD does not display anything instead it displays "black pixels"...
    adjust the voltage on the contrast input (see LCD datasheet).
  • Below is the code that i tried to program based on http://www.keil.com/appnotes/docs/apnt_161.asp
    I do not know whether the way i initialise the Input/Output Ports correctly??
    #include "C8051F200.h"
    #include <stdio.h>
    #include <intrins.h>
    void Reset_Sources_Init()
        WDTCN     = 0xDE;
        WDTCN     = 0xAD;
    void Port_IO_Init()
        // P0.0  -  Unassigned,  Open-Drain  Digital
        // P0.1  -  Unassigned,  Open-Drain  Digital
        // P0.2  -  Unassigned,  Open-Drain  Digital
        // P0.3  -  Unassigned,  Open-Drain  Digital
        // P0.4  -  Unassigned,  Open-Drain  Digital
        // P0.5  -  Unassigned,  Open-Drain  Digital
        // P0.6  -  Unassigned,  Open-Drain  Digital
        // P0.7  -  Unassigned,  Open-Drain  Digital
        // P1.0  -  Unassigned,  Open-Drain  Digital
        // P1.1  -  Unassigned,  Open-Drain  Digital
        // P1.2  -  Unassigned,  Open-Drain  Digital
        // P1.3  -  Unassigned,  Open-Drain  Digital
        // P1.4  -  Unassigned,  Open-Drain  Digital
        // P1.5  -  Unassigned,  Open-Drain  Digital
        // P1.6  -  Unassigned,  Open-Drain  Digital
        // P1.7  -  Unassigned,  Open-Drain  Digital
        // P2.0  -  Unassigned,  Push-Pull   Digital
        // P2.1  -  Unassigned,  Push-Pull   Digital
        // P2.2  -  Unassigned,  Push-Pull   Digital
        // P2.3  -  Unassigned,  Push-Pull   Digital
        // P2.4  -  Unassigned,  Push-Pull   Digital
        // P2.5  -  Unassigned,  Push-Pull   Digital
        // P2.6  -  Unassigned,  Push-Pull   Digital
        // P2.7  -  Unassigned,  Push-Pull   Digital
        PRT2CF    = 0xFF;
        PRT3CF    = 0xFF;
    // Initialization function for device,
    // Call Init_Device() from your main program
    void Init_Device(void)
        Reset_Sources_Init();
        Port_IO_Init();
    sbit RS = P2^5; // RS for P2.5
    sbit RW = P2^6; // RW for P2.6
    sbit E = P2^7; // E for P2.7
    #define LINE1_ADDR 0x00 // Start of line 1 in the DD-Ram
    #define LINE2_ADDR 0x40 // Start of line 2 in the DD-Ram
    /* Display-Commands */
    #define CLEAR_DISPLAY 0x01 // Clear entire display and set Display Data Address to 0
    #define DD_RAM_PTR 0x80 // Address Display Data RAM pointer
    #define DISP_INIT 0x38 // 8 bit 2 lines
    #define INC_MODE 0x06 // Display Data RAM pointer incremented after write
    #define LCD_ON 0x0C //Turn on LCD
    * ReadInstrReg: Read from Instruction Register of LCD Display Device
    static unsigned char ReadInstrReg (void)
            unsigned char Instr;
            P3 = 0xff; // DATA PORT is input
            RS = 0; // select instruction register
            RW = 1; // read operation
            E = 1; // give operation start signal
            _nop_ (); _nop_ (); // wait
            Instr = P0; // read Instruction
            E = 0;
            return(Instr);
    * WriteInstrReg: Write to Instruction Register of LCD Display Device
    static void WriteInstrReg (unsigned char Instr)
            RW = 0; // write operation
            P3 = Instr; // write instruction
            E = 0;
            P3 = 0xff; // DATA_PORT is input [prevent I/O-Port from damage]
    * ReadDataReg: Read from Data Register of LCD Display Device
    static unsigned char ReadDataReg (void)
            unsigned char val;
            RS = 1; // select data register
            RW = 1; // read-operation
            val = P0; // read Instruction
            E = 0;
            return (val);
     * WriteDataReg: Write to Data Register of LCD Display Device
    static void WriteDataReg (unsigned char val)
            P3 = val;             // write value
            E = 0;
            P3 = 0xff;            // DATA_PORT is input [prevent I/O-Port from demage]
    char putchar (char c)
              unsigned char line;
              if (c == '\n')
                line = ReadInstrReg ();
                if (line & LINE2_ADDR)
                    {       // is already in line 2
                  WriteInstrReg (LINE1_ADDR | DD_RAM_PTR);   // place to start of line 1
                else
                  WriteInstrReg (LINE2_ADDR | DD_RAM_PTR);   // place to start of line 2
              else
                    WriteDataReg (c);
              return (c);
    void wait(unsigned int time)
              int i;
                for (i = 0; i < time ;i++)
     * Clear_Display: Write 0x20 to Display RAM
    static void Clear_Display (void)
              WriteInstrReg (CLEAR_DISPLAY);
              wait (1);
    void main (void)
      unsigned char c;
      for (c = 'A'; c < 'H'; c++)
        putchar (c);
      printf ("Hello \n");
      Clear_Display ();
      for (c = 0; c < 10; c++)
        printf ("This is Display Line %bd\n", c);
      while (1);
    /*void main (void)
            unsigned char c;
            { // Put the characters A to H to the display
            putchar (c);
            printf ("Hello \n"); // Puts ‘Hello’ to the display using printf()
            Clear_Display (); //Clear the display and reset cursor
            printf ("This is Display Line %bd\n", c); // another printf() testing
            //while (1); //never stop
