LPC2129 UART ISR Problem
I'm using the LPC2129 and Keil Tools. The purpose of the code is to interrupt on the receipt of a single byte of data and assign "data" to its value. The interrupt seems to work however "data" isn't the right value. Please help, Thanks.
#include <stdio.h> /* prototype declarations for I/O functions */
#include <lpc21xx.h> /* LPC21xx definitions */
void U1ISR(void) __irq; //Declare UART1 IRQ ISR
int data;
int main (void) {
PINSEL0 = 0x0005800A; // Enable UART1
U1LCR = 0x83; /* 8 bits, no Parity, 1 Stop bit */
U1DLL = 8; /* 115200 Baud Rate @ 15MHz VPB Clock */
U1LCR = 0x03; /* DLAB = 0 */
U1IER = 0x1; //Enable the RDA interrupt
VICVectAddr0 = (unsigned long)U1ISR; //Set UART1 ISR Vector Address
VICVectCntl0 = 0x20 | 7; //Enable Slot, Set Channel 7
VICIntEnable = 0x80; //Enable Int UART1
blah ... blah ... blah
while (1) {
yada ... yada ... yada
void U1ISR(void) __irq {
U1IIR |= 0x01; /* Clear Interrupt */
data = U1RBR;
VICVectAddr = 0x0; /* return from interrupt */
