I want to check if there is an equivalent instruction of the MOVX at the C language.
I tried doing in-line assembly with no luck.
Any assistance is appreciated
XBYTE[0x1234] = 0x55;
will produce: mov dptr,#0x1234 mov a,#55 movx @dptr,a
and will move 55 into absolute location 0x1234 in xdata.
Thanks for your help, but the thing is that I intend to interface IDE HDD and it deals with 16-bits. How can I do that? because as far as I know xbyte is for 8-bit data. Many Thanks
"as far as I know xbyte is for 8-bit data"
The 8051 is an 8-bit procesor - that means it can only ever handle 8 bits at a time!
16 bits is just 8 bits - twice!
I'm using AT89C51SND1C chip which is 8051 archeticture. It has a feature to interface the IDE after enabling this option it uses DAT16H register for transferring the higher byte. your assistance is appreciated
You asked, "... I intend to interface IDE HDD and it deals with 16-bits. How can I do that? because as far as I know xbyte is for 8-bit data."
Then you said, "AT89C51SND1C ... has a feature to interface the IDE after enabling this option it uses DAT16H register for transferring the higher byte."
Doesn't that answer your own question?
Doesn't the Atmel documentation show you how to use these things?
yes, but in the assembly language. I'm trying to find the equivalent of such instruction in the C language. Many Thanks
Don't Atmel and/or Keil provide a C51 header file?
What is your specific difficulty in 'C'? Have you looked in the C51 Manual?
http://www.keil.com/support/man/docs/c51/c51_le_memtypes.htm
http://www.keil.com/support/man/docs/c51/c51_le_sfrs.htm
http://www.keil.com/support/man/docs/c51/c51_le_absvarloc.htm
