I am using e-mail because your 'gateway' does not allow attachments
For product info etc refer to call 334462 (a solved issue of mine)
I have used
c:\tools\keil\c51\bin\bl51 SLVstart.obj, SLVisr.obj, SLViic.obj, ... SLVmain.obj, SLVxdata.obj, SLVzdata.obj, ... SLVUmain.obj, as.lib, c51s.lib TO as.omf ... RS(256) IX >protl.log
without any problems for a while. Now I want to add a bootloader and try to the best of my understanding of the CO description in the manual this which gives errors
c:\tools\keil\c51\bin\bl51 SLVstart.obj, SLVisr.obj, SLViic.obj, ... SLVmain.obj, SLVxdata.obj, SLVzdata.obj, ... SLVUmain.obj, as.lib, c51s.lib ... CO ( ?PR?SLVUmain?SLVUMAIN (0xe000), ?PR?CUP*) ... TO as.omf RS(256) IX >protl.log
.src of the first (SLVUmain) and one consecutive module is attached
The intention is to locate SLVUmain at 0xe000 and the CUP* functions following it
In advance, thanks
Note This message was edited to reduce width.
I have used the Keil LX51 linker (i.e. not BL51) to do something similiar in the past.
The following would work in that linker.
SEGMENTS (?PR?SLVUmain?SLVUMAIN (C:0XE000), ?PR?CUP*)
Maybe using the extended linker is an option for you?
C:0XE000
I wonder, do you need the address qualifiers for addresses on the command line with BL51 as well?
No, you don't.
The BL51 Linker has segment-specific directives (CODE, XDATA, DATA, IDATA, and so on) that you use to specify the addresses for segments in these areas.
The LX51 Linker uses a generic SEGMENTS directive for all segment types. And, you need to specify qualified addresses (with the segment prefix).
Jon
At casual glance, it seems that this command line would work. Is there a specific error that you get?
