I m using MSC1210. It receives data on UART0. SCON=0x50--> Serial mode 1(Asynchronous full-duplex). However, in simulation, only RI(receive interrupt) happens, TI never gets set. As per the code TI should get set:
SBUF='@'; //These 3 lines are not setting TI bit SBUF=0x0D; SBUF=0x0A; //copying the string into array for(z=1;z<=4;z++) { while(SCON0==0x50){} init_arr[z]=SBUF; SCON0=0x50; } P0=0x00; //comparing the string if (init_arr[1]=='I' && init_arr[2]=='4' && init_arr[3]==' ' && init_arr[4]=='A') P0=0x0F9; else P0=0x0C0;
Please tell me if i m wrong and why it wouldnt work as intended.
hi your code is right, me too at a loss why it is not working,
Wonder what our experts (Andy Neil) has got to say,
