How to write code to help complier store variable into register??
Hi all
I try to use Generate Assembler SRC file to see the assembler code ,I found the complier is smart
enough to stroe variable into register sometimes ,
but sometimes is strange. I try to complier same code
twice times ,one time, it will sotre into register ,
one time is not,Why??
The first time ,I got this
?XD?int0_hander?MAIN
SEGMENT XDATA OVERLAYABLE
RSEG ?XD?_int0_hander?MAIN
?int_hander?BYTE:
msgsts?040: DS 1
intsts?041: DS 1
The second time,I got this
msgsts?040 is stroe in R2 register
intsts?041 is also stroe in R2 register
Another example,I have a interrupt handler function
it just read clear the interrupt status register
void irc_int_hander(void)
 intsts = ptr_reg[IRC_INT_STS];
dma_task_scheduler(0,0,0);
why "insts" will not store into register ,there is R2,R6 are free, but others more complex code can do this well.
any comment is welcome
Best Regards
