Why my variable become to zero??
hi all
This is a piece of my coce,it complier by large model
In main.c
uchar volatile xdata *data ptr_reg;
unsigned char pdata g_size;
void dma_task_execute (void) small
  size =  g_size;
  do_something();
void main(void)
 while (1)
EA = 0;
dma_task_execute();
EA = 1;
In Int.c
extern unsigned char volatile xdata *data ptr_reg;
extern unsigned char pdata g_size; void int_handler(void) interrupt 2
{ EA = 0; g_size = ptr_reg[X_addr]; EA = 1; }
I found the data store into g_size in int_handler function is correct,but why g_size will become to zero when run dma_task_execute() sometimes ?? The vlaue of g_size is never will be zero,but why it will become to zero in dma_task_execute() sometimes?? Sorry my poor english any comment is welcome Best regards
  • Thanks all
    Sorry,the variables of g_size and ptr_reg has realy
    initialized to zero before program running.
    my question is in the interrupt rountine,the g_size will be assign to some value ,but back to main ,the g_size value will become to zero sometimes.
    I have check the SRC to see asm code,it look like well
    Best regards
  • Thanks all
    Best regards
