info 9° bit in LPC 2364
Hi at All
I'am start with MB2300 board and KEIL demo version,
I must implement the Master/Slave comunication with 9° bit detect for addres and data comunication.
The LPC2364 not have this feature. Is possibile implement this function use the SW model? what is the max speed Ican use in this function for one corret functoinality on the serial Master/Salve Comunication?
You have any sample code for this utility?
Regards
Franco
  • The usual trick is to fiddle with the Parity bit to "spoof" a 9th bit - you'll have to check the Datasheet so see if this is possible with your chip.
    Alternatively, the 8051 handles this natively - so perhaps you could just use a small, cheap 8051 as a slave "IO processor" just to manage this 9-bit interface...?
