How the printf() function works?
I have wrote a simple program to use the c51's function printf(). as belows:
void main (void) { //initial_UART: SCON = 0x50; /* SCON: mode 1, 8-bit UART, enable rcvr */ TMOD |= 0x20; /* TMOD: timer 1, mode 2, 8-bit reload */ TH1 = 0xFD; /* TH1: reload value for 9600 baud @ 11.0592MHz */ TR1 = 1; /* TR1: timer 1 run */ TI = 1; /* TI: set TI to send first char of UART */ // TI is my question location!! // main while(1) { printf("1234\n"); } }
When i set the TI=0 in the part of "//initial_UART", the printf() function will always waiting for the the condition "TI=1", so ,it will not run out of the printf() function. this can be see in the assembly mode: C:0x1234 JNB(TI(0x98,1),C:0x1234).
But when i set the TI=1 in the part of "//initial_UART" , this program will run well and serialed out "1234" continually as i want.
My question is coming: when the TI is set to 1 first, after the printf() run first time ,when "4" was sent out of SBUT ,the TI bit will be CLEAR by the printf() herself (the assemble line is : CLR TI(0x98,1)),when printf() want to run the second time ,it find the TI is 0,so printf() will always waiting for TI to 1 and halted, NOTHING will be serialed out i think, but the fact is the printf() function was run sucessfully again and again.
What's the matter? there is someting set the TI to 1 after send out the last data from the SBUF? or the printf() have not RESET the TI to 0 when the last data send out ???But as we know, TI should be reset to 0 when the TI was became to 1. am I right?
For a description of how any specific implementation of any standard library function works, your first point of reference must always be the appropriate compiler Manual.
In this case, the relevant page is: http://www.keil.com/support/man/docs/c51/c51_printf.htm
Look at the bullet-point Notes at the bottom of the page - they tell you how the actual output is implemented, and you can follow the links for further details that will answer your question...
