printf and interrupts
I need receive data through the uart via interrupts. I am using the philips 89lcp935 which claims to have separate tx and rx interrupts. As soons as I enable the Rx interrupts in whatever mode, I get tx interrupts when I printf(from MAIN) and nothing comes out of the uart as the transmit interrupts are not enabled. If I enable them then I get one character and no more until I manually set TI...where upon I get another character etc.
I was expecting that if I disabled the tx interrupts then printf would work normally, but it doesn't seem to be doing that. Any ideas? Also, with separate tx and rx ints (CIDIS ==1) the debugger never shows and access to the tx interrupt routine that code architect generates. Could it be that the interrupt vector generation isn't supported correctly, or could I just be doing something daft?
Any assistance would be greatly appreciated.
Regards
Ian
