Using uVision, I'm not getting .obj files produced by C51. A51 produces .obj files OK in the same project. The example projects do produce .obj files, so the cause is likely project settings. A .LST file contains:
NO OBJECT MODULE REQUESTED
; COMPILER INVOKED BY: ; C:\Program Files\Keil\C51\BIN\C51.EXE BANK2.C LARGE OPTIMIZE(SIZE) BROWSE NOINTPROMOTE DEFINE(RAA_Limits=0) DEBUG OBJECTEXTEND OBJECT(.\Obj\BANK2.obj)
Thanks.
"NO OBJECT MODULE REQUESTED"
So the compiler thinks that you specifically asked it not to produce an Object Module - and it hasn't!
Have you used the SRC directive...
http://www.keil.com/support/man/docs/c51/c51_src.htm
Are you using a full version or an Eval Version of the tools?
Full version.
