memory map changed
Load "C:\\Keil\\C51\\Examples\\Chipcon\\RF\\halRFtest\\halRFtest_433"
*** error 65: access violation at I:0x80 : no 'write' permission
616: INT_SETFLAG(INUM_TIMER0,INT_CLR);
C:0x13BF C28D CLR TF0(0x88.5)
Memory Map
001: I:0x00 - I:0x7F read write
002: C:0x0000 - C:0xFFFF exec read
003: X:0x000000 - X:0x00FFFF read write
error caused by Timer0 ISR trying to clear the timer
overflow flag at TCON^5, when I try to reset Memory
to what the User's Guide calls for.
0x000000 - 0x00FFFF read/write this should be IDATA that overlaps the SFR's right?
0x010000 - 0x01FFFF read/write this is XDATA
0xFF0000 - 0xFFFFFF exec read this is CODE
I have try'ed to enter the default map for small memory model using DeBug > Memory Map but keep getting
error:invalid address range given.
what could have caused the change in the memory map
and how should i change it back, please help
Calvin
  • when I try to reset Memory to what the User's Guide calls for.
    I'm reasonably sure no User's Guide applicable to Keil C51 calls for that memory map. You've mixed up memory spaces (code,data,idata,xdata) and their internal encoding for generic pointers. The debugger uses prefixes to indicate memory spaces. And no '51 on this planet has a DATA space going up all the way to 0xffff.
    You've also misinterpreted the error message. It is not about the machine instruction you've shown. It's about an instruction using indirect access to address 0x80 --- probably the one directly before the one you've shown. The reason for that is perfectly clear from the memory map as shown: you configured the tools to believe your chip has only 128 bytes of internal RAM --- a property that's pretty much nonexistant in today's '51 controllers.
