How to Generate 21KHz frequency Sine wave Using 8051
I need to generate 21KHz frequency sine wave using a 8051 MCU. Can any one help where in I can find refrence source about generation of of sine wave
  • Hy,
    i adapted my programm to your needs :-)
    ;Digital Frequency-generator
    ;assuming XTAL = 40MHz
    Timer0_repeat_cycles:    EQU    40     ;cycle's between Timer_interrupts
    ;Frequency = 21000 * 65536 * Timer0_repeat_cycles / XTAL
    Frequency:      EQU     1376    ;value to be computed by hand!
            ISEG
            ORG     30H     ;behind bit-adressable-area
    Phase_low:      DS      1
    Phase_high:     DS      1
    RAM_end:
            CSEG
            ORG     0
            AJMP    Main
            ORG     0BH
            AJMP    Timer0_int
            ORG     080H
    Timer0_int:
            PUSH    ACC
            PUSH    PSW
            PUSH    DPH
            PUSH    DPL     ;save all used register
            MOV     A,Phase_low
            ADD     A,#low Frequency
            MOV     Phase_low,A
            MOV     A,Phase_high
            ADDC    A,#high Frequency
            MOV     Phase_high,A    ;16 bit phase-accumulator
            MOV     DPTR,#My_sintab
            MOVC    A,@A+DPTR
            MOV     P5,A            ;assuming 8-bit-DA-converter on P5
            POP     DPL
            POP     DPH
            POP     PSW
            POP     ACC     ;restore all used registers
            RETI
    Main:
            MOV     SP,#RAM_end-1
            ACALL   T0_int_init
    Loop:
            SJMP    Loop    ;My user programm
    T0_int_init:
            ANL     TMOD,#11110000B ;clear TMOD(0)
            ORL     TMOD,#00000010B ;Timer0 now 8Bit Reload
            MOV     TH0,#-Timer0_repeat_cycles
            SETB    TR0             ;Timer0 is running
            SETB    ET0             ;Timer0 interrupt is enabled
            SETB    EA              ;general interrupt is enabled
            RET
    My_sintab:
    DB 080H,083H,086H,089H,08CH,08FH,092H,095H
    DB 098H,09CH,09FH,0A2H,0A5H,0A8H,0ABH,0AEH
    DB 0B0H,0B3H,0B6H,0B9H,0BCH,0BFH,0C1H,0C4H
    DB 0C7H,0C9H,0CCH,0CEH,0D1H,0D3H,0D5H,0D8H
    DB 0DAH,0DCH,0DEH,0E0H,0E2H,0E4H,0E6H,0E8H
    DB 0EAH,0ECH,0EDH,0EFH,0F0H,0F2H,0F3H,0F5H
    DB 0F6H,0F7H,0F8H,0F9H,0FAH,0FBH,0FCH,0FCH
    DB 0FDH,0FEH,0FEH,0FFH,0FFH,0FFH,0FFH,0FFH
    DB 0FFH,0FFH,0FFH,0FFH,0FFH,0FFH,0FEH,0FEH
    DB 0FDH,0FCH,0FCH,0FBH,0FAH,0F9H,0F8H,0F7H
    DB 0F6H,0F5H,0F3H,0F2H,0F0H,0EFH,0EDH,0ECH
    DB 0EAH,0E8H,0E6H,0E4H,0E2H,0E0H,0DEH,0DCH
    DB 0DAH,0D8H,0D5H,0D3H,0D1H,0CEH,0CCH,0C9H
    DB 0C7H,0C4H,0C1H,0BFH,0BCH,0B9H,0B6H,0B3H
    DB 0B0H,0AEH,0ABH,0A8H,0A5H,0A2H,09FH,09CH
    DB 098H,095H,092H,08FH,08CH,089H,086H,083H
    DB 07FH,07CH,079H,076H,073H,070H,06DH,06AH
    DB 067H,063H,060H,05DH,05AH,057H,054H,051H
    DB 04FH,04CH,049H,046H,043H,040H,03EH,03BH
    DB 038H,036H,033H,031H,02EH,02CH,02AH,027H
    DB 025H,023H,021H,01FH,01DH,01BH,019H,017H
    DB 015H,013H,012H,010H,00FH,00DH,00CH,00AH
    DB 009H,008H,007H,006H,005H,004H,003H,003H
    DB 002H,001H,001H,000H,000H,000H,000H,000H
    DB 000H,000H,000H,000H,000H,000H,001H,001H
    DB 002H,003H,003H,004H,005H,006H,007H,008H
    DB 009H,00AH,00CH,00DH,00FH,010H,012H,013H
    DB 015H,017H,019H,01BH,01DH,01FH,021H,023H
    DB 025H,027H,02AH,02CH,02EH,031H,033H,036H
    DB 038H,03BH,03EH,040H,043H,046H,049H,04CH
    DB 04FH,051H,054H,057H,05AH,05DH,060H,063H
    DB 067H,06AH,06DH,070H,073H,076H,079H,07CH
    i would recomand you a forth order butterworth-filter at the output of your DA-Converter.
Reply Children
