1) what is the diffrence between unsigned char far* pointer and unsigned char* pointer? 2) what is the diffrence between unsigned int far* pointer and unsigned int* pointer?
Why don't you read the manual:
http://www.keil.com/support/man/docs/c166/c166_le_memmodels.htm
- mike
I think should ask like this How many bytes are allocated for each type of declaration? It is not mentioned in this
The manual, again:
http://www.keil.com/support/man/docs/c166/c166_ap_datastorage.htm
