I'm borrow the phyCORE HD200 (LPC2294) dev borad from my friend. And he has lost the CD. I'm trying to run the EasyWeb example provided in uVision3. But fail to see anything at 192.168.1.110 (default IP), even cannot be pinged.
The Keil trial version I'm using is rvmdk301a.exe, download from Keil official site.
And I found 2 EasyWeb demos in the Keil default installation directory. C:\Keil\ARM\Boards\Phytec\LPC229x\EasyWEB and C:\Keil\ARM\RV30\Boards\Phytec\LPC229x\EasyWEB
But both do not work, seems need some modifications.
All setting are default. No change.
Only change made is the IP address, change to my sub-network.
Did you read this: http://www.keil.com/support/docs/2980.htm ?
