variables in debugger watch window not right...?
I was trying to make a simple static heap module, and when trying to verify proper operation of the heap functions via the debugger I got quite confused.
Whether I build and run the below code for an AT91SAM7S32 in the simulator or on my target hardware, local variables in the watch window change in ways that I just can't believe could be valid.
For example, when stepping through the heap_alloc function (for the first call to it from main), the blocksize variable changes every time I press F10 once I get into the part where I'm actually allocating the block. The comments show how the value of blocksize changes when I don't think it should be changing at all.
Can anyone shed any light on this...?
It doesn't matter whether I declare the heap variables at the top of the file as static or not, the wierd behavior is the same.
#define NULL (0)
#define HEAP_SIZE (1000)
static char the_heap[HEAP_SIZE];
static char* ptr_the_heap = the_heap;
static int heap_left = HEAP_SIZE;
int heap_size(void)
    return(heap_left);
void* heap_alloc(int blocksize)
    int remainder;
    int padding;
    void* ptr_block;
    // allocate blocks on 32-bit boundaries
    remainder = blocksize % 4;
    padding = 4 - remainder;
    blocksize += padding;
    if (blocksize <= heap_left)
        ptr_block = (void*)ptr_the_heap; // blocksize changes to 0x3E8 (1000) here
        ptr_the_heap += blocksize; // blocksize changes to 0x200000 here
        heap_left -= blocksize; // blocksize changes to 0x20000C here
        return(ptr_block); // blocksize changes to 0x3E8 here
    else
        return(NULL); // not enough space on the_heap for blocksize
int main(void)
    volatile void *p1;
    volatile void *p2;
    volatile void *p3;
    volatile void *p4;
    p1 = heap_alloc(1);
    p2 = heap_alloc(2);
    p3 = heap_alloc(3);
    p4 = heap_alloc(4);
    while(p1);
    while(p2);
    while(p3);
    while(p4);
    return(0);
Frustrated,
Dave.
P.S. I previewed this post, but the preview of it got really screwy in the code listing part as soon as I started using the wheel on my mouse to go up and down through the post. I hope it doesn't look that way once I actually post it!
