I want to include an assembly include file in a C file I am not able to do so using pragma
I tried the following -------------------------------------------- ;File1.asm TEST_MACRO MACRO mov a, r0 ENDM
//File2.c #pragma asm #include "file1.inc" #pragma endasm
--------------------------------------------- void main() { #pragma asm TEST_MACRO #pragma endasm
With this I cannot compile file2.c The src file formed is ------------------------------------------------------- //file2.src NAME FILE2
?PR?main?FILE2 SEGMENT CODE EXTRN CODE (?C_STARTUP) PUBLIC main ; #pragma asm #include "file1.inc" #pragma endasm
RSEG ?PR?main?FILE2 main: ; SOURCE LINE # 5 ; SOURCE LINE # 6 ; TEST_MACRO TEST_MACRO ; #pragma endasm ; ; } ; SOURCE LINE # 11 RET ; END OF main
END --------------------------------------------------------
Error is Cant open file name File1.asm
The #pragma endasm is not detected by the preprocessor
Please help.
Regards, Gaurav
You can't - the 'C' compiler understands 'C' syntax only.
However, the Assembler can understand some 'C' syntax - so you can put the bits that need to be shared between 'C' and assembler into a 'C' header using only the subset of 'C' syntax recognised by the assembler...
dfdddd
aaaa
"you can put the bits that need to be shared between 'C' and assembler into a 'C' header using only the subset of 'C' syntax recognised by the assembler..."
See http://www.keil.com/support/man/docs/a51/a51_mp_c.htm
See also: www.8052.com/.../read.phtml
