I'm having trouble using #pragma ASM/ENDASM inside a #define statement. This is what I want to do inside the #define:
- push ACC (assembly) - push IE (assembly) - EA = 0 (C)
This is the code I'm *trying* to use:
#define portENTER_CRITICAL() \ { \ #pragma ASM \ push ACC \ push IE \ #pragma ENDASM \ EA = 0; \ }
But I always get an error, no matter what I change... also, it seems that #pragma ASM/ENDASM can't be used inside header files (who knows why...), is there any workaround for that, without repeating the same #defines inside all .c files that uses it?
Best regards, Carlos.
PS: any one answering this thread, nevermind the "that's a bad practice! use separate asm and c source files! blah blah!..." comments... I really need this, so don't bother with those kind of comments...
"... it seems that #pragma ASM/ENDASM can't be used inside header files (who knows why...)"
It doesn't have anything to do with header files. It's because #pragma can't be used as part of macro expansion.
"is there any workaround for that ..."
No.
"I really need this"
What makes you think that you really need this?
If you explained what you're actually trying to achieve, people might be able to offer you solutions to your problem, rather than try to fix a fundamentally broken approach...
What I'm trying to do is port FreeRTOS (http://www.FreeRTOS.org) to the philips 51MX architecture (P89C669)...
The way freertos is made, to add support to other processors/microcontrolers one needs to make some architecture specific functions and some macros (#defines) . Those defines are used mainly for context switching, so they need to be done in assembly, to make use of push's and pop's. If anyone saw the freertos sources, you know what I'm talking about...
Regards, Carlos.
"Those defines are used mainly for context switching, so they need to be done in assembly"
Yes that is the kind of thing that should be done in assembly!
It really shouldn't be anywhere near a 'C' file!
"If anyone saw the freertos sources, you know what I'm talking about..."
I haven't, so I'll take your word for it...
If you're stuck with having to do it this way because of 3rd-party constraints, then I s'pose you'll have to go that way - even if it really is a "bad practice" blah, blah, etc...
So, although the source is "free", the work to port it is going to cost something - that's always the tradeoff: is it worth it, rather than buy something "ready-to-go"...? That's a call only you can make!
It says a port already exists to the SiLabs 8051-derivatives: www.freertos.org/main.html
could you get any tips from the way they did it?
Hello :)
Yep, I took Cygnal port as a base... The problem is the compiler... I'm using Keil and they use SDCC. SDCC suports assembly in #define statements, but doesn't support 51MX family, I think only keil cx51 supports 51MX...
I already "expanded" all #defines with the code that was supposed to be inside them (basically I've made the pre-processor work by hand :), but now I have linker errors saying that it can't find some libraries (I think it has to do with floating point operations)...
Regards and thanks for the replies :) Carlos.
"(I think it has to do with floating point operations)"
Why would an RTOS be doing floating-point operations...?!
It's only on the demo software, to test the RTOS. The logic behind that is the greater probability of a task being interrupted by a context switch between a float operation (sum, multiplication, etc...) than with a single byte operation...
regards, Carlos.
ANSI C does not allow preprocessor directives to be generated by #define.
There's one ugly way to do this just with the C preprocessor:
header.h -- ... #include "mypragma.pragma" ...
mypragma.pragma -- #pragma mypragma --
But I can't really recommend it.
Hello: I'm a newer here.
Free RTOS for 8051 SDCC compiler uses "pop/push _bp" instructions for restoring/storing the context during context switch.SDCC manuals says _bp is the stack frame pointer and keil doesn't allow compiling of the same.What could be the alternative?....how to port?...Anyone tried this?... Thanks, P.S.Manikandan.
"SDCC manuals says _bp is the stack frame pointer and keil doesn't allow compiling of the same"
Keil doesn't use a "stack frame" in the conventional sense!
Anyhow, "_bp" is an internal symbol of SDCC - you should never expect any compiler to understand the internal symbols of another compiler!
"What could be the alternative?"
I think you're going to have to do this in assembler.
"Free RTOS for 8051 SDCC ... how to port?"
First, you're going to need to gain a very thorough, in-depth understanding of how this "Free RTOS" works, and how it relies upon the specific implementation details of SDCC (this, of course, implies an in-depth understanding of the specific implementation details of SDCC itself); Next, you're going to need to gain a very thorough, in-depth understanding of Keil's implementation details; Then - and only then - you will be in a position to understand how to adapt "Free RTOS for SDCC" to Keil.
Again, this so-called "free" RTOS may have a zero price tag to obtain, but it certainly has a non-zero cost to implement!
Would it not be simpler just to use SDCC?
Or, if you must use Keil, why not use an RTOS supplied & supported by Keil?
