Dear all, We are using MDKv3.05 and ULINK2 for programming STR912 devices.But for the field people we can't provide full version of keil.Is there any way to use the .AXF file generated at factory can be downloaded only using JTAG,without using keil.Please help us.
Regards, Anuradha.
You can program the ELF file with the same technique as explained here, but specify the .axf instead of the .hex file:
http://www.keil.com/support/man/docs/uv3/uv3_fl_hexdownload.htm
