Hi to every body
I use uVision3 for compile a program.My program have some of .h and .c files. In one of them that called "guts.h", I define :
typedef struct yaffs_DeviceStruct yaffs_Device; typedef struct { __u8 tagByte0; __u8 tagByte1; __u8 tagByte2; __u8 tagByte3; __u8 pageStatus; __u8 blockStatus; __u8 tagByte4; __u8 tagByte5; __u8 ecc1[3]; __u8 tagByte6; __u8 tagByte7; __u8 ecc2[3]; } yaffs_Spare;
and in other file that called "mtdif.h", I define like this:
#ifndef __YAFFS_MTDIF_H__ #define __YAFFS_MTDIF_H__ #include "yaffs_guts.h" int nandmtd_WriteChunkToNAND(yaffs_Device * dev, int chunkInNAND,const __u8 * dat, const yaffs_Spare * spare); #endif
But it has error. The error is : "undefined yaffs_Device"
But when transfered this code to mtdif.h the error removed:
what is the problem? The problem when increase that I include guts.h in some of my files. In all of files that use variables that defined in "guts.h" has error. what is problem? what I do for solve it?
Thanks very much
hi zsa zsa,
where you you youuuuu define yaffs_DeviceStruct ????
K
In guts.h
The code you posted does not show a definition for yaffs_DeviceStruct.
Please post the full, complete error message - use copy-and-paste, do not manually re-type it.
