Cypress CY7C68013A USB Bulk transfer problem
Hi Frnds,
I am using Cypress CY7C68013A EZ-USB micro controller, I have used BULKLOOP example given by cypress, where they have given a loop back transaction between EP2 to EP6, But I have changed the code for transmission of 64bytes of data as bulk on EP1, below code which i have written for bulk write operation, when i run this code it is transferring 64bytes of data ,but as a JUNK data, what is the mistake in this code, if there is any mistake please through some light on it.
 if(!(EP01STAT & bmEP1INBSY))
          //Source is Internal RAM Buffer
                memset(UsbBuffer,'\0',64);
        APTR1H = MSB(&UsbBuffer);
        APTR1L = LSB(*UsbBuffer);
        // Destination is External RAM at 0x2800
        AUTOPTRH2 = MSB(0x28);
        AUTOPTRL2 = LSB(0x00);
        EP1INBC = 0x40;   //64KB
        count = EP1INBC;// (EP2BCH << 8) + EP2BCL;
                SYNCDELAY;
        for( i = 0x0000; i < count; i++ )
           EXTAUTODAT2 = EXTAUTODAT1;
                SYNCDELAY;
//              EP1INBC = 0x40;   //64KB
                APTR1H = MSB(0x28);
        APTR1L = LSB(0x00);
                AUTOPTRH2 = MSB(&EP1INBUF);
        AUTOPTRL2 = LSB(&EP1INBUF);
                SYNCDELAY;
                SYNCDELAY;
        EP2BCL = 0x40;          // re(arm) EP2OUT
        u8TransmitFlag =1;
Rajesh
