I know that µVision support that a user can see the attributes from any userdefined structure in da dropdown-menu. For example:
typedef struct counter { INT32U MAXALLOWEDVALUE; INT32U CURRENTVALUE; }COUNTER; COUNTER C1;
When i'm editing and use
int main(void) { C1. }
i want to see on the right side the attributes in a dropdown-menu. Which option i have to activate?
no such option forum has lots of Ditchers around, and be careful not to give out your company code, do it yourself,
hehe no prob i work not for commercial useage, i work on a open source study work and so i have no problem with "Ditchers".
Okay there is also no option. and how can i make the drop down activ?
Okay... I give up...
What are these "ditchers" you mention...?
This is a feature which is not available at the moment at all.
oh yes, you can do it, just enable the appropriate template in the edit menue section.
Right, no such feature
and this is being a forum foir friends, where do "ditchers" come in ?? please,
