I'm debugging a firmware update problem and notice that uVison2 and 3 do not refresh the dissasembly or code memory views.
In other words, my app writes the new code into flash, but Uvision still thinks the old code is there.
Is there a way to get the latest version of uVision to refresh it's view of flash?
Thanks,
Mark
http://www.keil.com/support/man/docs/uv3/uv3_cm_load.htm
The load options in http://www.keil.com/support/man/docs/uv3/uv3_cm_load.htm do not address the problem. I need to know what's actually in flash memory, not what I think is in flash memory or what Uvision thinks is in flash memory.
I'm using SiLabs usb debugger for their 8051 chips. The otherwise terrible SiLabs IDE has no problem refreshing it's view of flash directly from flash (what a concept!).
Than what is the problem, you just staed that it woeks.
Is it that you are incapable of working outside the Keil IDE?
I have used the SiLab ide for issues like this. It takes considerable time to make sure the everything is set up properly in the SiLab ide to match the settings of Uvision in order to create the exact image. This can take hours.
I don't want to use some crappy IDE, when the best tool just needs to refresh it's view of flash. This is not a difficult concept.
"It takes considerable time to make sure the everything is set up properly in the SiLab ide to match the settings of Uvision in order to create the exact image"
As a workaround, can you not just load the image built by uVision into the SiLabs IDE for this?
"I don't want to use some crappy IDE, when the best tool just needs to refresh it's (sic) view of flash."
Have you contacted Keil support about this?
What did you want to say.?
"I don't want to use some crappy IDE, when the best tool just needs to refresh it's (sic) view of flash." whats sic in that,
Have you contacted Keil support about this? Keil being BUSY, has time for BASIC queries..? I wonder,
